CELIV set up
Hi everyone- I am trying to set up a VI for Photo-CELIV. The experimental set up is below- does anyone have any idea what I need to put into the VI other than the XY graph?
Thanks!
Ellie
(2,057 Views)
Hi Ellie,
In your image there is a connection line between your computer/monitor and the scope: I guess you need to implement some communication with that scope!
(Based on that "PhD" in your nickname you should know that on your own…)
Btw. it always helps to explain abbreviations like CELIV when writing questions like yours!
(2,040 Views)
Hi GerdW,
I am in my first year and my first time using labVIEW so there is most definitely a steep learning curve!
By communication specifically what would I add to the panel?
Thank you!
Ellie
(2,033 Views)
Hi Ellie,
You should take the "Training resources" as offered in the header of the LabVIEW board to actually learn LabVIEW…
You need some communication with your device. Most often that will be VISA functions, but that could also be other communication functions…
In the end you start such developments by reading the manuals of your devices!
(2,019 Views)
