Re: Error -50103 : How can I get the resource which is reserved
did you manage to solve this:  I am trying to get a Bode plot and have two "DAQ's" but if I try two channels within 1 "DAQ" it throws a different error (buffer size).
The error changes depending upon continuous samples (which seem ok but buffer failure) or single samples that "fail" #
Error code = 50103  VI start task 72200002
(1,091 Views)
Hi ChemPC,
no need to hijack a 17 year old thread!
When you need more/better hep you should provide more information!
Which DAQ hardware do you use?
Mind to attach your VI?
(1,087 Views)
