SMA Sunny WebBox UDP data parsing
Hello, I have managed to get data from SMA Sunny WebBox using RPC through UDP, but I can't seem to convert the data from UDP read VI from a string to number after obtaining the values using array.
Any idea what type of string/data is coming out of UDP read VI?
I have also noticed the string for each letters have one spacing between each other.
I have attached some images below.
Jason
(2,368 Views)
After checking the code. I found out the output of the UDP read to be an ASCII code.
How do I convert ASCII code to back to normal strings?
Jason
(2,330 Views)
Seems I had fix the issue myself, thanks. Here the VI to log data every 15 seconds from SMA Sunny WebBox using UDP everyone 😃
The solution to the parsing was to simply strip '0' I have inserted.
(2,309 Views)
Hi Jason,
two comments:
  1. Those intermixed zero bytes seem to indicate UniCode is used instead of plain old ASCII for communication with your device. I guess the manual of your device should have explained that, but you forgot to attach the manual. (After reading the manual it is clear it uses UTF-8 encoding…)
  2. That subVI used to convert the UDP string into seperate items should use a cluster/array for all its output values to minimize the connector pane. And you should NOT use a local variable to send the string data into the VI: ever heard of RACE CONDITIONs before?
(2,305 Views)
UTF-8 does not use embedded 0 bytes. This is definitely UTF-16BE if it works like this. As long as you do not use extended ASCII characters, the LabVIEW strings would be directly compatible with UTF8, since the first 127 character codes in UTF8 are equivalent to the 7-bit ASCII codes that are also used in all normal Windows codepages for the first 127 characters.
Rolf Kalbermatter  My Blog
(2,297 Views)
Hi GerdW,
I took a few days break in between when programming this and I seems to have forgotten about the removal of '0's when I am back to programming it. 😅
In order to prevent race condition, what would be the better way to send string data to the VI. Do I link it directly? I realise the data from UDP is slightly slower than the data at the indicators.
I need those indicators on the GUI, would using array for the output values achieve the same results?
Jason
(2,279 Views)
Hi Jason,
Yes, usually you just use wires to transfer data! (Pretty basic LabVIEW stuff…)
In the end: yes.
I prefer clusters as you can label each cluster element individually…
(2,275 Views)
