CIN and hardware
Is it possible to drive hardware using CIN in labview 6.1, with external
API?
(2,908 Views)
> API?
Sure! But not necessary to write a CIN. If you don't already have a DLL
(your external API you refer to), just create a DLL instead to access
your hardware. Test it in your favorite environment and then write
LabVIEW VIs to call the DLL.
CINs are from days when DLLs couldn't be called and have little use
nowadays although I do hope NI does not discontinue them just now for
many old CINs I still have laying aroung. But creating new CINs for new
software is basically not a very good idea anymore.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,908 Views)
Rolf offers a very good solution. It is highly recommended to use DLLs instead of CINs. The real difference between the two is that CINs take the code and compile it into your LabVIEW code, whereas DLLs only call the code. CINs are also highly inefficient and application dependent, whereas DLLs do not have to be constantly recompiled to work.
Jeremy L.
Jeremy L.
(2,908 Views)
