Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Close Front Panel
Close Front Panel
sunil-online
Member
07-12-2004
04:36 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Is there a way to close the VI front panel from inside the VI? I can
trigger an exit of LabVIEW itself, but can't find an event to close
the front panel.
Thanks.
0
Kudos
Message
1
of 3
(3,409 Views)
Reply
Re: Close Front Panel
Dr._Imad
Active Participant
07-12-2004
04:55 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
use the vi
Close Panel.vi
found in
labview folder....\vi.lib\utility\victl.llb
1
Kudo
Message
2
of 3
(3,409 Views)
Reply
Joe_H
Active Participant
07-12-2004
05:00 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
First off if you are going to build this into an exe then don't worry about it. but if want to close the vi programmatically then here is an example.
Hope this helps you out
Joe
Joe.
"NOTHING IS EVER EASY"
Untitled.vi 20 KB
0
Kudos
Message
3
of 3
(3,409 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
