Close Front Panel
Is there a way to close the VI front panel from inside the VI? I can
trigger an exit of LabVIEW itself, but can't find an event to close
the front panel.
Thanks.
(3,188 Views)
use the vi
Close Panel.vi
found in
labview folder....\vi.lib\utility\victl.llb
(3,188 Views)
First off if you are going to build this into an exe then don't worry about it. but if want to close the vi programmatically then here is an example.
Hope this helps you out
Joe
Joe.
"NOTHING IS EVER EASY"
(3,188 Views)
