CIN crashed without any hint
Hello:
  I use a cin in my program,bu it works unstable,when the data comes to the cin then usually the labview crashed  with out any hint. But some times the data can go through the cin and the cin can give the right resoult. When i  copy the cin to another new vi,and  give the same input and output,then it works mostly right,and some times crash.
But I need the other part of the program to process  data, I do not know why it crashes so often and gives no hint ,i am really  puzzled. wish some one can give a help ,   Thanks !
(3,025 Views)
Can you post your vi?
(3,017 Views)
Hi ,Thanks for you help
here is the vi
if you need the data then i will post it out
(2,998 Views)
hello ,here is the data
hope to get further help
(2,985 Views)
I am sorry , I give a wrong data.
The original data is so large, about 100M
(2,976 Views)
