Vertical scroll bars update?
I have a VI that I want to update the vertical scroll bars after the table has enough data that the scroll bars can be used. By default as far as I can tell the data in the table does not cause the scroll bars to move automatically to show the latest data in the table. I came up with a way to do it but was wondering if there is a better way of doing it. The VI that I came up with is attached. Let me know if there any any other ideas with this.
Troy
Message 1 of 25
(7,079 Views)
Hi Troy
Could you post it as LV7.0?
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 25
(7,064 Views)
Here it is saved as version 7.0.
Message 3 of 25
(7,060 Views)
You could do it this way as well, which does not mean that this solution is better. Just another way to do the same.
Using LV8.0
Message 4 of 25
(7,057 Views)
And here's a simpler version without any sequence structure, writing to a Boolean, or the case statement.
Message 5 of 25
(7,051 Views)
Becktho-Thanks for the VI. This is a good solution as far as another way of making it variable.
Troy
Message 6 of 25
(7,025 Views)
Dennis what happens with negative values in your examples (e.g. if the size of returns a value smaller than the constant you wired)?
Using LV8.0
Message 7 of 25
(7,046 Views)
I am guessing that if the value is negative since the requirement is an unsigned 32 bit integer, it is ignored and set to the minimum of 0.
Message 8 of 25
(7,018 Views)
Dennis - Thanks for your response as well. I see what you are doing here to eliminate extra programming.
Troy
Message 9 of 25
(7,011 Views)
It's ignored.
Message 10 of 25
(7,038 Views)
