Vertical scroll bars update?
Rely on the SW to "ignore" different things is not that good, isn't it? Smiley Wink
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 11 of 25
(2,192 Views)
Ok guys I have one more part that I am currently trying to figure out. I also have a text box that is displaying spam from a serial port that I am monitoring/testing. The last part was pretty simple. This one seems a little more involved. I can see on the property node of the text box where you would set the vertical scroll box position but is there a property I can read that tells the program when the box is ready to be scrolled?
Message 12 of 25
(2,163 Views)
@Dennis Knutson wrote:
It's ignored.
No, it's not.  Not in 8.0, anyway.
Error 1077 occurred at Property Node (arg 1) in
Vertical_Scroll_Bar_Update_mod.vi
Possible reason(s):
LabVIEW:  Invalid property value.
Property Name:
Index Values
It seems that it converts -12 to 4294967284.  Darn wraparound!
Message Edited by jasonhill on 12-01-2005 09:06 AM
Message 13 of 25
(2,180 Views)
STRIKE!!! Smiley Very HappySmiley Very Happy
Using LV8.0
Message 14 of 25
(2,171 Views)
Damn, that's one feature in LV 8 I'm not too happy to see. Smiley Sad
Message 15 of 25
(2,144 Views)
Can you read the NumRows property and compare it to the current index?
Message 16 of 25
(2,142 Views)
Absolute value is your new best friend.
Crud. That wont work right either.  I don't like the "In Range? Coerce", because you have to specify an upper limit.  So many operations to get a proper select.  There does not seem to be an elegant solution.  Worse, upgrading from 7.x to 8.0 may cause buffer over-runs.  Robot tongue
Message Edited by jasonhill on 12-01-2005 09:27 AM
Message 17 of 25
(2,143 Views)
There is not a numrows property for a text indicator that I can find anyway. If you know different let me know.
Message 18 of 25
(2,133 Views)
I cannot think of any eligant way to do this.
If the lines are sufficeintly short, you could disable word wrap and count EOL and CRs.
If there are no EOLs or CRs, you could just count characters.
If the spam is totally arbitrary.... ick.
Message 19 of 25
(2,128 Views)
Well, you could specify +Infinity for the upper limit.
Message 20 of 25
(2,126 Views)
