CIT_verifyandmatch.vi error
Dear All,
I am using DSC module in LV8.6 for extract data form citadel database where i have runtime error
Here my PC name SBCPC and database vishnu.
What is missing in this so i have error.
--VP
(2,607 Views)
Hi Vkumar,
      I am using LabVIEW 2009 and i am getting the same error at my VI, do you found a solution?
Best Regards,
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
(2,581 Views)
Accepted by Vkumar
      This error is when the VI dont found the Shared Variable because the name does not was correct.
      In my particular case, i was using "Rename Historical Data.vi", I did change localhost at the path by the computer name and did work well.
Best Regards,
Luis A. Mata C.
Ing. Electrónico
BBM Pin: 2B83E99A
Thanks: Kudos
(2,573 Views)
