CLAD Graph problem
Which of the following allows you to plot any set of points, evenly distributed or not?
A  Waveform Graph
B  Waveform Chart
C  XY Chart
D  Both A. and C.
Please provide me the solution and explaination
according to me c must be the answer but i m not sure at waveform graph
Prashant Soni
LabVIEW Engineer
(5,492 Views)
Accepted by Prashant_S1
Correct.
Waveforms (whether chart or graph) always have evenly spaced points.  The XY graphs do not.
Charts store data in its history, graphs do not store data.
(5,488 Views)
Correct C is Answer..
Suggestion for building confidence on your answer will be to try it directly in LabVIEW also ..
- HS
(5,482 Views)
Or to look in the LabVIEW Help, since the answer is directly in there.  https://www.ni.com/docs/en-US/bundle/labview/page/types-of-graphs-and-charts.html
(5,466 Views)
In my case, theory study with practical will add more confidence with better learning .. So I always check myself by doing it practically, if option of doing so is in my hand Smiley Happy..
(5,461 Views)
