CLAD question
A.Blue represents Standard SubVI's, and red represents Express VI's.
B.Blue represents Standard SubVI's, and yellow represents Express VI's.
C.Yellow represents Standard SubVI's, and blue represents Express VI's.
 D. Red represents Standard SubVI's, and blue represents Express VI's.
 pls post the answer
(4,687 Views)
Accepted by Muralidharan
The answer is to just drop an express VI and regular LabVIEW function on a block diagram.
Perhaps you could keep all of your clad questions to the original thread you created?
(4,673 Views)
I do find that question a bit ambigues. When did NI decide to call the built-in nodes standard subVIs? I was always under the impression that there was a distinction between built-in nodes that you can't open any further and anything else that are (sub)VIs.
Rolf Kalbermatter  My Blog
(4,629 Views)
A subvi can be any color i guess. Isnt it?:smileyindifferent:
(4,626 Views)
Yes but I would assume that the term Standard subVI was intended to mean what I would refer to as built-in node. Also the possible selection of color combinations clearly would point in that direction.
Still I find this another of those ambiguous questions where the wording makes things rather unclear.
The answer isn't to difficult if you exclude the obvious wrong ones based on Express VI color. And multiple choice questionnaires tend to have this kind of problem no matter how hard one tries to come up with unambiguous wording.
Message Edited by rolfk on 05-17-2010 09:37 AM
(4,606 Views)
Blue represents Express VI's. That's sure. I don't understand the other part of question ...
(4,480 Views)
