CONVERSION
Hola.
Es posible conectar una terminal de tipo "enum constant" a una terminal de tipo "unsigned word" ? Estoy usando LabView 2015
Anexo foto de lo que quiero conectar
(1,604 Views)
I can't see any "unsigned word" anywhere in your picture. Please explain.
(1,596 Views)
Hi Jeovany,
@Jeovany12 wrote:
Is it possible to connect a terminal of type "enum constant" to a terminal of type "unsigned word" ?
The answer is "Yes!".
Try this:
(You can also omit the ToU16, but then you get a conversion dot.)
(1,543 Views)
Maybe you mean something like this? You want to get the TEXT (String) from your ENUM constant? But my example is not with an ENUM constant.
regards
(1,526 Views)
