CONVERTING STEPPER MOTOR STEPS INTO DEGREES
Hello, guys, I am working on a project which involves rotating a camera lens with the help of stepper motor. project is basically determining the max focused position of lense that's why I need to know by how much degrees the motor is moving. I have attached LabVIEW file in which motor is moving in steps I want it to move in degrees
As I am new to LabVIEW I will be very thankful if anyone of you could help me with this.
Thanks in Advance
(5,541 Views)
Hi diehard,
How many steps make a full revolution?
(Once you know the answer the rest is simple math…)
Btw: no need to scream the thread title!
(5,532 Views)
Hi, GerdW
Thanks for reply 48 steps make a full revolution, I request you please see the LabVIEW file I have attached
(5,517 Views)
Accepted by diehard
Hi diehard,
So the angle calculation is "360° * steps/48"…
I don't see how that VI is related to your question.
There's a missing subVI and no comments at all in the VI…
(5,511 Views)
Accepted by diehard
Of course the math will be a lot easier to implement if you're code is clean.
Before:
Spoiler
After:
Spoiler
Just a thought...
(5,509 Views)
Hello all, I am working on one project in which I am rotating a lense with the help of stepper motor by 1 mm, 0.1 mm for determining a point of maximum focus for the lense. The problem is attached vi was given by my professor in which it is moving stepper motor in mm I want to change it to a degree of rotation. since I am new to LabVIEW I am not able to understand this vi's. it would be very helpful if anyone could help me with this problem and also suggest some good source for learning LabVIEW.
for stepper motor 48 steps= 1 rotation
(5,469 Views)
Hi diehard,
why don't you stick with your thread?
We already "solved" the conversion from steps to rotation angle - so what's your problem now/again?
See the "Training resources" offered in the header of this LabVIEW board!
(5,402 Views)
