COUNT TIMES A CASE STRUCTURE IS ACCESSED
Hello
I have a case structure inside a while loop. I would like to count how many times the TRUE case is executed and to be able to reset this "counter".
I think its something trivial but i'm stuck for some hours now! If anyone can help i will appreciate it very much.
Thanx in advance guys.
I am using LV7.1.
(3,453 Views)
Hi I_Pant,
create a shift register on your while loop. connect a constant with value 0 to it. Now connect the wire to the case structure, add a "+1" function and do to the other side of the case structure. connect both tunnels in the false case without a function in it. Now you can count the "true" cases. Add another case structure after your first one and connect a boolean button to it. Connect a "0" constant in the true case to the output, and the input value in the false case.
[Edit] here is a picture Smiley Happy [/Edit]
Mike
Message Edited by MikeS81 on 05-28-2008 12:51 PM
(3,452 Views)
thank you Mike....
(3,448 Views)
