 alrahal1
			alrahal1
			12-12-2022 06:32 AM - edited 12-12-2022 07:16 AM
Hi!
please i need help
i am trying to connect CR touch probe with myDAQ then use Labview code to get result .
regards
 Bob_Schor
			Bob_Schor
			12-12-2022 06:58 AM
Please do not ask us to do your homework for you. If you need technical help, please provide more complete information. Include all of the following:
			12-12-2022 06:58 AM
Hi alrahal,
@alrahal1 wrote:
please i need help
Which part do you need help with?
Where are you stuck?
What have you tried?
12-12-2022 07:12 AM
Hi
the code i have used (please see attached file )
but i could not get to arm and disarm the probe .
12-12-2022 07:15 AM
thank you for your help but it is not a homework and i wrote the probe name that i am using so you can look it up
			12-12-2022 07:20 AM
Hi alrahal,
Is there any error from your LabVIEW code?
Do you get the expected output? Did you verify using a scope?
 Bob_Schor
			Bob_Schor
			12-12-2022 07:22 AM
Sorry, I'll pass ...
12-12-2022 07:27 AM
the code is working fine and i get a result when i used a servo as test
			12-12-2022 08:14 AM
Hi alrahal,
So what exactly is the problem?
Again I have to ask:
What is the problem?
12-12-2022 01:28 PM
The problem was with cr touch probe didn’t move ,I don’t know if I am doing something wrong with the code or what I need to change.
The idea is to have the touch probe binning disarm until it’s touch the surface.
it is similar to the idea in 3-D printer or the touch probe in CNC machine.
I appreciate your help
