CRC 32bit
      i am communicating with stm 32 via UART. The frame i receive is      "1C000000B0B80700040400000000000000" and the CRC of the frame is " 9D0351B5". its not matching the calculation of the crc which i do, the calcuated crc is " 226F9471" . I tried the calculation with python and other sources calculated crc works fine. If anyone how to solve, pleas elet me know.
Message 1 of 46
(8,722 Views)
Any clue about the code the microcontroller is running?  There are many variations on CRCs, so you pretty much need to know what algorithm is being used in order to get it to work.
Message 2 of 46
(8,697 Views)
Also things like high byte/low byte ordering are important which could "swap" by communication protocols.
Norbert
Norbert
Expert: Geometry
Message 3 of 46
(8,678 Views)
nope. I don't know that info. but i know the CRC calculation is according to the IEEE 802.3 standard. Also Communication is Little Endian.
Message 4 of 46
(8,674 Views)
@jay0909 wrote:
[...] Also Communication is Little Endian.
Are you sending the data litle endian?
Norbert
Norbert
Expert: Geometry
Message 5 of 46
(8,672 Views)
Hi
   Nope I recieve in Little Endian, as per the UART specs. I cannot send becos of the CRC problem.
Message 6 of 46
(8,668 Views)
Can you post your VI which includes the receiver part?
Norbert
Norbert
Expert: Geometry
Message 7 of 46
(8,665 Views)
I believe there is a nice set of CRC vis in the VIPM.
Bill
CLD
(Mid-Level minion.)
Message 8 of 46
(8,641 Views)
If it's works fine in python it should also work in LabVIEW.
Check with the way it's implemented in python and in LabVIEW and find the difference
Basic CRC is add all the data other than header .
Message 9 of 46
(8,607 Views)
         The attachment contains the code of the recieving end. I have segregated according to the frame format last 4 bytes after data is the CRC.
@ PalanivelT : Please read the whole post carefully.
Message 10 of 46
(8,600 Views)
