CREATING RANDOM ELEMENTS
THKS.I DONT HAVE ROUND NEAR TO ZERO FUNCTION MY PALETTE
Message 21 of 35
(8,172 Views)
  • When posting code post the actual code not a screenshot.  You wouldn't take a screenshot of a text file and post it on a text language forum.  Upload the actual VI, or zip several files and upload the zip.  The exception to this rule is when uploading a VI Snippet.  This is an image with the VI embedded in it, so the source is still intact.
https://decibel.ni.com/content/docs/DOC-40451
Message 22 of 35
(8,170 Views)
Sorry, I must have been thinking of another language.  Round Toward -Infinity will work here as well.
P.S.  You don't have to yell.  Just read that document Hooovahh linked to.
Message 23 of 35
(8,166 Views)
Message 24 of 35
(8,159 Views)
1. You will want to multiply by 4 (remember, we have 4 possible options to choose from here).
2. Get rid of the Index Array.  It is just confusing things.
3. As was said, you will want the Length input for the String Subset to be 1
Message 25 of 35
(8,150 Views)
IF I USE INDEX ARRAY,WITH SOME CONVERSION I CANT ABLE TO CONNECT
Message 26 of 35
(8,137 Views)
Message 27 of 35
(8,129 Views)
can you please help me,that i can able to generate characters,but i have to store them continuously,how can i do that
Message 28 of 35
(8,118 Views)
finally i did can you please check it.thanks for your help..all
Message 29 of 35
(8,111 Views)
Accepted by topic author balbal207
This is a clear case of "I have no clue what I am doing so I am just going to make random connections until it compiles."  Seriously, take a minute to think through the process.  As you have it, you will just get "abcd" followed by a whole bunch of b (50 of them to be exact).
1. GET RID OF THE INDEX ARRAY.
2. initialize the shift register with an empty string.  There is a nice Empty String Constant to make your life a little easier.
3. Wire the "abcd" constant to the String input of the String Subset.
4. Wire the output of the String Subset to your Concatinate String to combine the substring with the string you are saving in the shift register.
Message 30 of 35
(8,099 Views)
