CRIO9074-FPGA Error
Hello everyone,
I work with CRIO9074 and transfer the project I developed on the microcontroller side to the FPGA side.
Although I compile and run my project on the FPGA side, I started to get a new error and now I cannot compile and run the fpga program.
I tried again by creating a new project but it did not work again.
I don't understand what this error is caused by, because the working system started to stop working.
Below is the error screen, can you help?
(664 Views)
Accepted by btncan
Hi btncan,
just do what the message says!
You are changing from Scan engine to FPGA mode, and you need to apply the correct settings...
(646 Views)
