CSV conversion pro
Hi Gerdw,
Thank you for getting back to me,
ive attached the VI,
i assume i have set it up wrong 😞
cheers
Richard
Message 11 of 14
(1,571 Views)
Accepted by NewRichard
This is a common (and understandable) beginner mistake.  The Decimal String to Number function actually returns an integer.  What LabVIEW means by "decimal" is "base-10" as in, "we use the decimal (base-10) system".  To convert your string properly, you need to use Fractional String to Number, instead.  While the name of the function is technically accurate, let's say the name choice was an "unfortunate" one.  People will always associate a "decimal" number with a number that has a whole number with a decimal point.
Bill
CLD
(Mid-Level minion.)
Message 12 of 14
(1,572 Views)
A common error: yes.
Understandable: no - a beginner should always read the LabVIEW help to learn about a "new" function…
Message 13 of 14
(1,565 Views)
Hi Bill,
Thank you for The knowledge, and the solution 🙂
you are correct, everything works as expected now 🙂
Message 14 of 14
(1,559 Views)
