CVI device driver DLL
I tried to use CVI device drivers under LabVIEW 6i. The problem ist
that the device driver DLLs are missing. Is it possible to create
these DLLs without LabWindows, or create them with LabVIEW? I tried to
create them with a gnu compiler, there some c-source- and
c-header-files are missing. I need the DLLs for the device drivers
bp14xx, hp3325a an 3457a. Can anyone tell me how to get these DLLs?
Best regards
Jens
(3,323 Views)
The CVI drivers for the HP3325 and HP3457 are very old it appears and were propabley created before plug and play and the need for DLL distribution. The only way to create the DLL required is with LabWindows and even then might take some effort to work. However, LabVIEW drivers do exist for the HP3325 and HP3457. Go here, select Agilent as the manufacturer and download them. I don't know about your BP14xx. Who is the manufacturer and what is the exact model number.
(3,323 Views)
