LabVIEW Application
my question is about the resolution of the applications, I need that when my aplicasion is executed, this unfolds in all the screen of the computer and that is not distorted, since when launch my aplicasion in another computer with different size from screen appears you distort. How can i solve it?
(2,772 Views)
From the VI, goto File >> VI Properties >> Category >> Window Appearance. Check "Size the Front Panel to the Width and Height of the Entire Screen". Don't check "Scale All Objects on Front Panel as the Window Resizes".
You'll see the effect when you run the VI. Each time you load the VI, it will be set to its original size until you run it. You could also set File >> VI Properties >> Category >> Execution to Run when Opened.
(2,772 Views)
