simple curve fit
I am writing a VI where i want to do a curve fit, I have an X and an Y array
and want to do a simple curve fit, the fit has to be exponential. I've
looked up the examples but i doesn't get it to work? Can anyone give me a VI
where there's an X and Y in and a fitted X and Y out? Thanks in advance!
Best Regards,
Thijs
(2,528 Views)
Exponential Fit.vi, which is found on the curve fitting palette should work. It takes an X an Y array in and gives you a Y array out. You don't need a fitted X out, because X isn't fitted. Just use the same X array that you used as the input. If this still isn't working for you, post a VI that contains the data you are trying to fit (use the menu option: Operate >> Make Current Values Default to save the data in the VI's controls or indicators).
Good luck,
Jim
(2,528 Views)
