i'm sure the mathematics are the same with which used in the original ASYST program
I'm sure that the mathematics are the same as what are used in the original ASYST program
Message 1 of 13
(3,317 Views)
Are you asking if this VI executes the same as an ASYST program? Is that ASYST program available? I've never used ASYST before, but if you post it here I could try and take a look at it for you.
J.R. Allen
Message 2 of 13
(3,317 Views)
Thank you very much, JRA.
I'm lonely struggling with this language. Sometimes very frustrated.
I'm trying to translate the ASYST program into LABVIEW. The two programs should use the same input and give out the same output.
Here is the ASYST program. I re-typed in notepad without it's plotting the results.
Message 3 of 13
(3,317 Views)
also the sub vi and global variable used are attached
Message 4 of 13
(3,317 Views)
could you save the program as LV 6.0
Message 5 of 13
(3,317 Views)
I don't know how to do it.I'm usingLV 6.1.
let me try
Message 6 of 13
(3,317 Views)
I did it, the attached are the re-saved LV 6.0
Message 7 of 13
(3,317 Views)
Could you give the text of an operating Asyst program. In the file you attached definitions of variables are missing and some extra spaces are needed. Moreover, I would use a formula node to programm that algorithm.
Message 8 of 13
(3,317 Views)
This is the ASYST code for the whole program. I 've asked my friend to do it in MATLAB acording to my decoding of the ASYST simulation subroutine(CAL). He also got the same wrong result as what I got in LABVIEW. So I wonder if my decoding of the ASYST simulation program is wrong.The subroutine which does the simulation in this program is "CAL". I also attached the program IMPLOG.END called by IMPLOG.123.
I'm sorry I did not reply to you earlier because I did not recevie NI's notification that you responded to my question.
Thank you so much. Happy V's day!
Message 9 of 13
(3,317 Views)
Hi Fenny,
Here is a corrected Labview program together with the Asyst code used for testing. Now both of them give the same value of parameters (zzss in inLabviev and zs in Asyst). For testing I used an array which you have to replace with your data. Also, if you require the Asyst environment you could download it for free from the Keithley homepage.
with best wishes,
Andres
Message 10 of 13
(3,317 Views)
