LabVIEW Application
my question is about the resolution of the applications, I need that when my aplicasion is executed, this unfolds in all the screen of the computer and that is not distorted, since when launch my aplicasion in another computer with different size from screen appears you distort. How can i solve it?
(2,765 Views)
These settings are all controlled in one place. Select VI properties and choose the Window Size option. There you can tell the VI to fill the entire screen, maintain proportions, etc. For the best results, you might want to develop at the lowest resolution you're likely to use and stick with the default LabVIEW fonts.
(2,765 Views)
