01-06-2005 07:11 AM
01-06-2005 07:31 AM
01-06-2005 07:37 AM
01-06-2005 07:58 AM
@Ben wrote:
I left this one for you CC.
It may be time for you to change your icon.
The frog icon made a lot of sense because of your interest in "bugs".
Maybe a nice image of those caves plotted in 3-space would be more good.
Ben
01-07-2005 11:04 AM
01-07-2005 02:50 PM
01-07-2005 03:21 PM
@Radman wrote:
Have either of you tried to use the application builder to build a self-executable 3-d plotter based on CWgraph3d? I was able to do this but you do not have the ability to change any of the graph properties when running from the self-executable.
01-07-2005 04:07 PM
01-11-2005
08:20 AM
- last edited on
06-03-2026
09:11 AM
by
Content Cleaner
The 3D graph CWgraph3d is actually an ActiveX control originally written for ComponentWorks (hence the CW), which was the forerunner to MeasurementStudio. If you want the full functionality for the 3D graph, you will have to install it on the host machine. You can either do this manually, or have the Application Builder do it for you. You can add the .ocx file as a support file, create an installer, and set it to run a batch file to register it on the host machine.
