CWGraph3d show z axis color ramp
Hello!
I use CWGraph3d. Is possible to show the color ramp (legend) for z axis data? Similar like by Intensity chart.
Thanks for an answer!
(3,082 Views)
Hi Toni2,
The legend display in a CWGraph3D does not work like that in an intensity graph. It is an ActiveX object and therefore, in order to edit any properties you have to get inside the LabView properties window. Please refer to this knowledgebase article for more information regarding this. You basically have to get inside the object and alter its properties.
Ipshita C.
(3,046 Views)
Ipshita,
 Your "this knowledgebase article " link did not work.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,043 Views)
Ipshita_C: Publish the link please!
(3,035 Views)
Accepted by topic author Toni2
Hi all,
Please refer to this link. This only explains how to use the property node--I expereimented with it myself and found that you can set foreground and background legends but nothing in particular for the axes.
Ipshita C.
(3,027 Views)
