CWIMAQ labview
Can I display a picture saved on the hard disk using the CWIMAQ viewer in LabVIEW?
If it is not possible, how to display a picture in the front panel in LabVIEW?
__
Sadok
(3,810 Views)
in front panel, try this
(3,809 Views)
Thank you very much! 🙂
Is it possible to display it in CWIMAQ viewer?
(3,804 Views)
I don't know whether this will help.
but have a look at here
(3,800 Views)
Sadok,
I think there is a little confusion here. CWIMAQ is a text based viewer. If you would like view an image from file in LabVIEW you can:
1. Create an Image Display on the front panel and wire the Image data type to this on the block diagram
                   OR
2. Use the WindDraw VI to display this image in another window programmatically. I've attached a simple VI demonstrating this.
Message Edited by Michelle_B on 12-01-2008 02:20 PM
--Michelle
(3,750 Views)
Accepted by topic author Sadok
Thanks a lot, intresting application!
I solve the problem:
In my application I use the CWIMAQ to display inspection from vision builder, What I was looking for is to use this component to display other pictures in addition of  inspections.
So I integrate the pictures in Vision builder and I display it as if it was inspections.
(3,745 Views)
