Caculate phase difference between two sine waves
hey guys.........
excuse me, could i join this discussion......???
i've same problem with moreins.......but i've more complicated signal,
i've tried VI from krisna to get phase different of my signal, but i got different phase shift from each method, is it normal?
because the difference between method 1 and method 2 is too far, i.e in method 1 = -150, method 2 = -2.84 E-14
would anyone like to explain about this???
thanks
Message 11 of 17
(3,751 Views)
Hey fandi,
This thread is a bit old. You are likely to get more support if you were start a new thread and reference this one. Anyway, I am not sure what the two methods you are referring to are. What happens when you run the sample code put together by Krisna? What do your two signals look like that make them more complicated?
Hope this helps.
-Ben
WaterlooLabs
Message 12 of 17
(3,727 Views)
Hi fandi,
Try to extract a single tone (your main frequency) and then measure phase diference between signals.
António Veríssimo de Freitas
Universidade de Aveiro Student
Message 13 of 17
(3,602 Views)
Hey how can i download the attached file? When i try to download or save a copy it show "The requested resource () is not available."
Message 14 of 17
(2,786 Views)
Hi ahmun,
Which file are you trying to download?
If you were trying to download the Phase Measure Folder.Zip from Krisna Wisnu, I have reloaded it on here to see if that helps. You may also just try downloading it from another internet browser.
The attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense.
Tommy G.
Product Manager - Search, My Account, and Chat
Message 15 of 17
(2,761 Views)
 How to get the difference between two signal not at the same time.
For example, I use DAQ to measure a sine signal Ur at time t1. After that, I have a signal Ut consist of Ur + Un measure at time t2. Now I want to get the Un = Ut - Ur signal. How to do it?, I get each signal, but it is difference phase, can not subtract together. Plz help me. Thank you
Message 16 of 17
(2,373 Views)
Hi tuananhtbbk,
Can you please provide a little more clarity in what type of difference you’re looking for? Are you looking to find the difference in magnitudes or do some sort of frequency analysis on the signal?
Additionally, you have posted in a forum post that’s over three years old. You will have better responses from the community if you create a new thread and provide a little more detail in your question.
Christine S.
Message 17 of 17
(2,342 Views)
