Calculate Enthalpy values from Temperature using lookup table method
I am reading data from 4 temperature channels on a scanner using RS 232 of a Vapour Compression Refrigeration System.
Data from each of the channel is stored into an array.
Every temp.channel has different temp. range ----- for eg. Suction temp.is below 0 degree celcius and discharge temp.is kind of above 100 degree cel.
Overall temp.range for all the 4 channels would be from -50 to 500 degree celcius
Now, I want LabVIEW to automatically generate Enthalpy values for a given temp.from a "Lookup table" kind of thing.
For that, I would generate a table containing Temperature & corresponding Enthalpy columns referring to Property chart of R134a refrigerant .
For instance, lets say I create a table with temp.values with every 10 degree step-
Temp.       Enthalpy
-10               100
0                  200
10                300
20                400
30                500
But what if my temp.falls somewhere in between 10 to 20 ; some intermediate value like 15.7 or something?
For this reason, I need to do some interpolation which will calculate corresponding Enthalpy values for such intermediate value.
How to do this?
There is a VI called "Interpolate 1D" in the functions pallette, but I am unable to understand how it functions.
Kindly educate me in this regard. I am using LabVIEW 8.2.1 Kindly post your suggestions by saving your VIs in this version.
Thanks in advance.
-Snehal Upadhye
CLAD
Message 1 of 20
(10,608 Views)
Hi Snehal,
as a CLAD you should know all this:
As the snippet tool of LV2013 mangles the blockdiagram (by replacing the array constant by a control and a scalar constant) I attach a real picture too:
Message 2 of 20
(10,596 Views)
The snippets made by the code capture tool don't have these issues, in case this really bothers you. You can install the CCT from VIPM. Just saying.
___________________
Try to take over the world!
Message 3 of 20
(10,558 Views)
Thank you GerdW.
Though I am CLAD I have never come across any such application which would require some kind of interpolation; hence it is not necessary that every CLAD should possess knowledge about everything in labview.
Now , I have another question- How to write a table with below mentioned format in labview i.e with merged cells.
I know how to write a table in labview; but not able to write in the same format that is given below.
I want all my four enthalpy columns merged under a same column "Enthalpies(KJ/Kg)". How to do it?
Sr.No.
Suction Pressure(Bar)
Saturation Temp
DischargePressure
Saturation Temp
Enthalpies(KJ/kg)
Density at T3
P1
ts1
P2
ts2
H1
H2
H3
H4
1
2
3
4
Thanks & Regards,
Snehal Upadhye
CLAD
Message 4 of 20
(10,512 Views)
Hi Snehal,
are you talking about a table indicator on a LabVIEW frontpanel or about a "table" aka Excel spreadsheet?
Table indicators do not allow merged cells...
AFAIK Array interpolation functions are also asked for in the CLAD exams. As a CLAD you should have (atleast) the knowledge to know where you have to look for appropriate functions...
Message 5 of 20
(10,508 Views)
Hello GerdW,
Thanks for reply.
I need a table indicator on labview front panel in given format.
I have already written it to excel spreadsheet; but my front panel table indicator also should appear like the table I have shown.
For any exam everybody prepare in their own way so its just might be that I havn't come across any problem regarding array interpolation; though I already knew that there is a function called interpolate 1d array and where it is located!!!
Thanks & Regards
Snehal Upadhye
CLAD
Message 6 of 20
(10,491 Views)
Is there any function which would give interpolated output from combination of two inputs?
My first problem was solved with Interpolate 1D array function; Now I need to obtain enthalpy values from combination of temperature & pressure inputs.
I have total three columns for eg. ----
Pressure              Temp.           Enthalpy
1                           10                  100
2                           20                  200
3                           30                  300
I want LabVIEW to give me enthalpy values considering "both" the temp.and pressure readings.
Kindly suggest me some solutions. Thanks in advance.
Best Regards,
Snehal Upadhye
Message 7 of 20
(10,441 Views)
Hi Snehal,
LabVIEW also has functions to do 2D interpolation...
Message 8 of 20
(10,429 Views)
Hello GerdW,
Thanks for reply.
Before writing this post ; I have already tried using "Interpolate 2D" function with method "Bilinear" but the results were not as expected.
I think I am missing something somewhere that I am not able to identify.
Could you please give an idea which would help me finding my loopholes?
Thanks & Regards,
Snehal Upadhye
CLAD
Message 9 of 20
(10,407 Views)
Hi Sneha,
Can you explain what was expected and what you got. may be post vi/screenshot if possible will give better idea.
uday
Message 10 of 20
(10,400 Views)
