Calculate average in table
I have a table in which i am getting some readings. I want to calculate the average of the cells which are shown in the image. (Please see the attached image)
Thanks in advance.
Message 1 of 8
(5,652 Views)
hi kaush, I cant open ur vi as i dont have labview 8.6. I hope u have used Table control.I have attached an example.
hope it will help you.
Best  luck
Gaurav kSmiley Happy
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 2 of 8
(5,642 Views)
Thanks for the reply gaurav. But unfortunately your VI is not working.. 😞
Message 3 of 8
(5,632 Views)
U have used the solution in your code only,
U can get the three values as shown in the fig attached,get their mean and in the same way write it in the table with the help of row and column.
Hope you got the solution
Message 4 of 8
(5,624 Views)
Accepted by topic author kaush
Jim
Message 5 of 8
(5,622 Views)
Find the solution.
Message Edited by Baji on 06-03-2009 04:22 PM
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 6 of 8
(5,619 Views)
Hi jcarmody
         Nice solution without loop and shift register,great thinking.
Balaji PK (CLA)
Message 7 of 8
(5,610 Views)
Thanks a lot   🙂
Message 8 of 8
(5,606 Views)
