Calculate frequency response from filter coefficients
I'm using an adaptative filter algorithm for getting filter coefficients and I would like to see the frequency response of the output filter. Is there any easy way to get Bode diagram or similar of a discrete transfer function in general (from coeffiecients and sample frequency.
(I'm using LabVIEW 6.1)
(4,000 Views)
You might try ...\vi.lib\measure\macond.llb\ma_Compute H(w) from IIR Cluster.vi and ma_Compute H(w) from h(n).vi. These VIs output a uniformly sampled magnitude and phase response of the given filter. To obtain correct frequency axis scaling simply multiply the output df from these VIs by your sampling rate to get the actual df.
(4,000 Views)
Here is a link to an example program which creates a Bode Plot. I am not sure if this will be exactly what you need, but it will put you on the right track:
Creating a Bode Plot from a Set of Stimulus and Response Signals [link removed; example no longer available]
(4,000 Views)
