Calculate the number of the last X minute peaks
Hi.
I am working on a SW which counts the peaks comes from a sensor.
Using Producer/Consumer method , one in aquiring the data and the second is finding the peaks using peak detector VI.
I was wondering if there is a simple way to calculate and show the number of peaks in the last X minutes . For example, in heartbeat there is average heart bear and the most updated last minute count of beats.
Thanks.
Message 1 of 8
(3,075 Views)
Are you keeping all the raw data from the sensor over the X minute period?  If so, simply feed the subset of the array of data representing X minutes to the Peak Detector.vi from the Signal Processing palette.  It has an output for number of peaks.
Another approach is to keep a running count in a shift register.  Every time you find a new peak, add one to the count. Reset after X minutes.
Lynn
Message 2 of 8
(3,067 Views)
Dear Lynn.
Thanks for your quick answer.
The number of peaks should include only the last 1minute interval counts. like a dynamic 1 minute that always moves according to the time which includes only the counts in the last 1 minute interval. For example,
Absolute running Time =60 sec.
time range to search for peaks - 0-60seconds.
Absolute running Time =150 sec.
time range to search for peaks - 90-150seconds.
and so on....
Thanks.
Message 3 of 8
(3,036 Views)
I would try it with a ring buffer only holding the time of a peak/pulse.
Buffer size would be max_pulserate (200 🙂 ) times max_time.
Calculating pulses per time frame would be a compare  and add array 🙂
A picture tells more :
Greetings from Germany
Henrik
LV since v3.1
Message 4 of 8
(3,029 Views)
Point to add: Maybe it's wise to use the actual time for the time comparison 😛
In case of no pulse the display would stay at the last value 😄
Beep .. beep ..... beeeeeeeeeeeeeeeeeee(...)
Henrik
LV since v3.1
Message 5 of 8
(3,027 Views)
Thanks.
I didnt finish to go over it deeply.
In the meanwhile, can you save the VI in LV 2011?
Message 6 of 8
(3,024 Views)
here we go...
another possible improvement: Since the array of timestamps is sorted you could get a more precise value if you use the time between first and last pulse of a integration time ....
Henrik
LV since v3.1
Message 7 of 8
(3,013 Views)
Dear Henrik
I put your code into my VI but with no sucess to retrieve the time for the pulse.
Attached, the VI . What am I missing?
Thanks.
Message 8 of 8
(2,998 Views)
