Calculating in a String array
Dear
My string array will be transformed to a floating type array.
Some element of the string array has no value(just "Empty").
In this case, I believe I have to treat the special case (for example, in average calculation).
In earlier LV version, NaN (0 / 0) is useful technique.
But what is the technique in LV8 for my purpose?
Lee
(3,434 Views)
If NaN was fine in earlier LabVIEW versions, do the same in LabVIEW 8.0.
(3,429 Views)
NaN technique is not proper in calculating standard deviation or average, which can take an array as a inut.
The result is NaN if the array include one NaN.
Therefore I have to exclude NaN elements by a temporary array in my calculating.
Am I right?
(3,409 Views)
Yes, it all depends on the problem.
Only you can decide if omitting all values containing NaN will be a valid and reasonable operation. Usually the presence of NaN means something. What if all values are NaN? Do you know why some values are NaN?
(3,398 Views)
In my case, I used NaN as an invalid measurement result by assigning to an "empty" string element in array.
Therefore, I didn't include them to my calculating some mathematics as well as the total number of index of the array.
Thank you so much.
(3,386 Views)
