array
Hi there,
I need to make a low-frequency counter. Please see my attachment. I use "Input" button to simulate digital input. The counter LED and # change shows if there is a change happen (i.e. 0 to 1, or 1 to 0). Everything is ok until I found problem with my output array. The "straight array" show all data per 1 sec (delay). Nothing wrong with that array, but I want my array only consist of logic value and the time when the change happen. I try to make "filtered array" but I can't get rid off the empty value for the array. Any idea ? Tx
Ghost Recon Team Leader
(3,194 Views)
You were just stripping data out of the array -- not deleting the index.  I adjusted your filtered array to only build on change by adding a shift register.  Let me know how it works.
Tom
(3,182 Views)
Thank's Tom, it works perfectly !!! You really solved my problem.
Ghost Recon Team
(3,164 Views)
