Calculator programme not working if second number is greater than 1 digit.
I have been putting together a calculator on labview, which works except for when I input a second number the calculator doesn't produce the correct value if the second number is more than 1 digit. I believe this is down to the use in shift registers and the fact the operation is forgotten when a button is pressed. I've attached the programme, if anybody could confirm that this is the problem / suggest potential methods around this problem that would be a great help
(2,939 Views)
Use Default if Unwired.  Several of your tunnels are set this way, including the orange (double precisions) wire where you are storing your first operand.
If you execute an event where a wire is not wired through, the tunnel will output the default value (empty for string, zero for double), and the shift register will then forget whatever it originally had in it.
(2,930 Views)
Accepted by Alxs93
I think you meant don't use Default if Unwired?  I think you meant to tell him to use Linked Input Tunnel --> Create and Wire Unwired Cases instead?
Bill
CLD
(Mid-Level minion.)
(2,908 Views)
You're right.
Uncheck the setting on the tunnel "Use Default if Unwired"
I wasn't thinking of Linked Tunnels at all.  Just that they need to wire through all the cases.  Of course Linking the tunnels and setting that to wire them is the more automatic way of doing it.
(2,904 Views)
Thank you! The programme works perfectly now!
(2,879 Views)
