Calibration due date
Is there a way to read in a string and convert it to a date stamp??  What I want to do is have the Admin update a text file w the calibration date of the test set.  When its 30 days from the cal date the displayed date turns yellow.  I can do that.  When its past due it turns red...no problem.  When I read in the cal date from a text file and type cast it the year is wrong.
Example:
text file:  12/15/16
read in as a text file, type cast : gives 12/15/1903.
Unless someone has a better idea on how to have admin update cal date periodically and have LV read it in.
Thanks..
(4,415 Views)
Accepted by topic author Clint1000
You mean like this...
(4,403 Views)
thanks..
(4,386 Views)
