show index of selected element - 2d array
hello everyone,
i have a 2-D array indicator, I need to display the row and column of the element that is selected with the cursor.
Any ideas?
thank you
Lorenzo
Message 1 of 8
(4,552 Views)
Hi loba,
Yes, you can use a property node with Arrelement.Value proterty selected.
I made you a code.
Regards.
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
Message 2 of 8
(4,539 Views)
It's kind of ugly, but it's the only way I know to do it:
Message 3 of 8
(4,535 Views)
Here another way.
Spoiler
Message 4 of 8
(4,528 Views)
thanks boyz. Got it!
Message 5 of 8
(4,517 Views)
Your VI returns the value, the OP asked for the indices.
Message 6 of 8
(4,513 Views)
Depending what you are trying to do, you might consider using a table instead of the array indicator (if you are using strings, you can just pipe a 2D array straight to it).
Then on the mouse up event use a property node to look at the SelStart property - this gives the row and column that was clicked.
Message 7 of 8
(4,503 Views)
If it is an indicator, may be it is better to use table, not 2D array? It has mouse click "Point to Row Column" method, relatively easy cell highlight
Message 8 of 8
(4,495 Views)
