TDMS get position
Is there a way to get the current TDMS position? something like the "Get File Position.vi" VI but for TDMS files.
I have a large data file, and I want a way to jump to specified percentage of the file and read it, for ex 30%. I'm thinking to move to the end of the file and get its position's offset, then use that # to determain the 30% position.
(3,814 Views)
Accepted by topic author EEOMARK
the channel property contains the # of elements for that channel:
NI_ChannelLength
You can use it to calculate the starting % and use it to get a fixed number of data points.
TDMS file is a structured file.  A random offset most likely is not a valid position for a channel.
Joe
(3,783 Views)
Thanks Joe, this works for me.
(3,694 Views)
