Call Labview Exe and Use its property like activex
HI ,
I have a small query , I would like to know if any one has tried using an Exe built on LV and call the same , be able to use the properties similar to active x components.
Sundar.
(2,493 Views)
Hi Sundar,
Thank you for contacting National Instruments.  I want to clarify your question, and make sure I understand it.  You are wanting to create an exe file in LabVIEW, and then use it in another VI using Active X controls?
If so, I was able to find another discussion forum that may be helpful.
Let me know if I have misunderstood your question.
Kevin H
WSN/Wireless DAQ Product Support Engineer
(2,472 Views)
