Call Library Function Error Message
Hi guys:
I have a new problem now. When I try to run my VI. It generate the following error message:
"LabVIEW: An exception occured within the external code called by a Call Library Function Node. This might
have corrupted labVIEW's memory. Save any work to a new location and restart LabVIEW.
"VI 'test.vi' was stopped at node 0x0 of subVI 'NI_APPLPro.lvlib:Real SVD decomposition.vi"
However, when running the VI on other computers or with LabVIEW 8.2, I DO NOT encounter this error message.
I've read a few other posts regarding this kind of error messgae. Some claim that it's the "result of badly
configured or wired Call Library Nodes."
http://forums.ni.com/ni/board/message?board.id=170&message.id=223900&query.id=305602#M223900
But I never used Call Library Nodes myself and I didn't change any configuration. I've attached the VI's
with this post.
Can some one help me out? Thanks
(2,872 Views)
(2,859 Views)
