I have upgraded to newer version of labview, and the older versions of LavVIEW are now piling up. Can I uninstall the older versions? if yes how?
Do I have to keep all the old versions of LabVIEW as I did not uninstall the older versions, but only downloaded the latest version of labview from the website and installed it. A new version and icon is installed on my PC now. What can I do?
(3,812 Views)
You asked "Do I have to keep all the old versions...". Of course not. You can do whatever you want. Each version of LabVIEW installs in its own directory, which is what allows you to keep multiple versions installed in case you need to support programs written in earlier version that cannot be upgraded yet for whatever reason. Conflicts may arise if you install older versions later than new ones and you install the libraries for the hardware interfaces like VISA and such. Older versions of these libraries sometimes cause problems with newer versions of LabVIEW.
If you do not want multiple versions, common practice is to completely uninstall the current version before installing the new one. If you have more than two versions but only want the latest, simply uninstall the older ones from the main NI installer. Depending on how old the versions are that you are uninstalling something with the new one may break so you may need to repair that installation. You may just want to simply uninstall all NI software and then just do a clean install of the latest version. That will likely be your best course of action.
(3,801 Views)
Dear smercurio_fc,
Thanks a lot for the reply. I tried uninstalling the older versions from Add/Remove programs but labVIEW does not show up there. You wrote that I should uninstall the older versions using NI installer. Where can I find the NI installer.
sincerely,
Munir.
(3,792 Views)
There should be an entry called "National Instruments Software" in the Add/Remove Programs list. Select this and click "Change/Remove". This will display a dialog showing all NI software installed on your system.
(3,789 Views)
