Call MATLAB Function
I was keen to try the new Call MATLAB Function node in LabVIEW 2021 and learned that if you make changes to the m-file, you must kill the MATLAB process before running the VI again.
For example, put the attached VI and M-file in the same directory and run the VI.  We can see that B = 1 - A.  Screen Shot 2021-08-23 at 00.42.10.png
Change line 3 of the M-file to B = 1 + A, and we still get
But if we kill the MATLAB process
and re-run the VI, we now have the expected behavior of B = 1 + A.
Is this the intended behavior?  Either way I'm posting here so others know what to expect.   
(6,450 Views)
Did you restart the VI after the change was made or went straight for the kill?
(6,448 Views)
I just checked - closing the VI doesn't change this behavior.
Quitting LabVIEW, however, has the same effect as killing the MATLAB process.
(6,437 Views)
Accepted by resono-mp3
It's a known issue, see https://www.ni.com/en/support/documentation/bugs/21/labview-2021-known-issues.html
It claims it's resolved in LabVIEW 2022. Not sure what to make of that...
(6,434 Views)
I have built an executable in LV2022Q3 calling an m file. But after closing the reference, the matlab process remains active. Only when I terminate the app, the matlab process terminates as well.
I ended up calling a second m file that kills the matlab process! Obviously an error is returned in Labview, but that can be simply ignored.
I also learned that if you get an error when calling a matlab function, chances are that you cannot rerun the routine without getting the same error over and over again. You will need to kill the matlab process first.
(5,870 Views)
kill script:
function exit_()
    feature getpid;
    cmd = ['!taskkill /F /PID ' num2str(ans)];
    eval(cmd)
end
(5,858 Views)
Shame btw that the call matlab function won't also accept string input.
(5,856 Views)
