Call SubVI
Hello
I have a SubVi,in the program all the variables are fixed. I need to call this subVi in other program.
Any suggestions pls
Message 1 of 28
(4,924 Views)
I suggest you create at least 1 input to the subvi. That way you can wire the subvi and control the time of the call. Then you can just wire the subvi into the program.
Message 2 of 28
(4,915 Views)
Thanks Joseph
now i have created a subvi with 3 input and 3 outputs, 2 i/o are connected to the terminals in the subvi program, but i am unable to copy the subvi icon to the other program.
I not bit clear with this,pls give some suggestions
Message 3 of 28
(4,913 Views)
How did you add it in?
Generally I add it in by doing a select a VI. At that point it brings up a menu to allow you to navigate to the location where the subvi is located. At that point you just select it and it should just be added to the program.
Make sure you save the subvi as a file or into a library file before you add it into the program.
Message 4 of 28
(4,908 Views)
Thanks Joseph
I made a mistake,its showing the terminal now. But actually i dont  need those terminals in my main program at all becoz the values are fixed. Just i need that subvi to execute in main program.
I read from the NI help that we can do that by Call Reference, give me ur suggestions to this issue.
Message 5 of 28
(4,903 Views)
As I mention, just select the vi from the file and just slap it in the program. It will then execute sometime in the program.
Message 6 of 28
(4,899 Views)
If you want to call a subVI with it's default values, just call it. You really don't need to call it dynamically.
Message 7 of 28
(4,895 Views)
Thanks joseph and Dennis
Its fine.
My task in my main program i have a button,so when i press that it will start executing the subvi and needs to open the subvi front panel.
Similarly in a same program i need to call some 5 different Vis, each time i press the button corresponding to the vis it should start executing and needs to open the corresponding subvi front panel.
Pls let me know if this not clear
Message 8 of 28
(4,890 Views)
Pls ignore the previous message
Its fine.
My task is,in my main program i have a button,so when i press that it will start executing the subvi and needs to open the subvi front panel.
Similarly in a same program i need to call some 5 different  subVis, each time i press the button corresponding to the vis it should start executing and needs to open the corresponding subvi front panel.
Message 9 of 28
(4,889 Views)
From what I understand, you will be placing it in a loop. If it is based on pushing in a button, you will need to place it in an event structure or a case structure. otherwise placing it in the loop, it will execute every time you do a loop.
Message 10 of 28
(4,885 Views)
