Call SubVI
Thanks Joseph
Pls could you explain more detail, also if u have examples that is helpful for me
Message 11 of 28
(1,900 Views)
Hi
With regards to my problem, what happens if clone method is used instaed if event structure. Because i have seen the clone example and it seems bit easier.
Message 12 of 28
(1,891 Views)
The example i have seen is reentrants program in the NI examples
Message 13 of 28
(1,889 Views)
Something doesn't make sense. Calling a subVI is extremely basic and is covered in basic tutorials that you should take. You keep mentioning things like dynamic calls, clones, reentrant and those are used for certain special applications and from what you have asked for so far, not at all necessary. You might want to explain in some detail why you are looking at those things. Are these subVIs all the same? Do you want the subVIs to all be open at the same time?
Message 14 of 28
(1,869 Views)
Apologize dennis,this is the 1st time i am using this SubVi and calling into main prgs.
Now i got it after reading the materials.
Also i got a question,I called the subvi through the call Vi reference into the event structure of main program,after executing it gives the error message 1000,what it means
Message 15 of 28
(1,866 Views)
The error means 'The VI is not in a state compatible with this operation.'
I have no idea why you are using the Call by VI Reference and unless you post the main VI and subVI, no one can tell what you have done wrong (aside from making things much more complicated than it needs to be).
Message 16 of 28
(1,864 Views)
Actually,i have to run many applications(for ex:5), from my main program i can choose which application needs to run.so if i choose application2 then its corresponding front panel should open so that i can see the results.
sorry if anything is wrong becoz just i am learning and developing prgs.
Message 17 of 28
(1,863 Views)
Thanks Dennis
I have attached the prgm
Message 18 of 28
(1,857 Views)
This would be the normal way to call a subVI.
As far as your example, as the help says, if you wire up to the type specifier input, you cannot use the Run VI method. Delete it and it will work.
Message 19 of 28
(1,854 Views)
Thanks Dennis
But after the selection of 1st application,the sub vi front opens and running but the main vi finishes
Message 20 of 28
(1,850 Views)
