Call a special function in the dll using Call Library Function Node????
Dear all,
      I am calling a special function in the dll using call library function node. There is a input parameter that it is a enum type in this function. I don't know how to deal this parameter for calling this function.:mansad:Has anybody solved this problem?Please advise!
      I am appreciated of you anytime.
(3,078 Views)
Most of the times an enum is just a U8/U16/U32, internally so probably you can call it with just a U8/U16/U32 or something. For the correct value you have to look at the definition.
Ton
My LabVIEW Ideas
(3,071 Views)
Dear TonP,
       Thank you for your advice. I have fixed this problem.
       Thanks again!Smiley Happy
(3,065 Views)
