Is it possible, when i call a vi from within my code, to pass to it parameters as input and to return some values too?
Hi There!
I am currently calling a vi from within my code. However, what i would like to do, is to pass it 2 int values when i call it and for it to return 2 int values when it is done!
Any advice on how i can do this please.
Thanks.
(2,848 Views)
If you have two controls and two indicators on the subVI, just wire them to the subVI's connector pane.
LabVIEW fundamentals
(2,839 Views)
Hi there!
Thanks for your reply. I have had it the way you mentioned.
This is the scenario, i have a main vi, lets call it Main.vi and from here i call another vi, lets call it X.vi. The X.vi can take parameters and return values.
The problem is that when i use the Open vi reference and use its property node's methods to open and run the vi, i do not know how to pass parameters to the X.vi and how to get return values back from it when it closes.
Please advise.
Thanks again.
(2,815 Views)
Hi Matrix,
is there a reason you do it this way? By Ref (it is called dynamically loading)
If you place the VI directly on the BD of a VI you can just wire things up.
Now if you need dynamically loading. hoover the open VI-ref function and right click on the type specifier and select create constant. Then right click browse, browse to your VI. Now you have the connector pane.
But if I were you I just use VI directly, because you'll keep connections active between the two VI's
Ton
My LabVIEW Ideas
(2,809 Views)
Hi again!
Thanks for your advice. I dont know why i wanted to use the dynamic way... But for the time being, it seems as if the normal static way should work.
Thanks again!
(2,807 Views)
