Call notifier in vit file
Hello all. I am using notifier for forward my datas.
I creating a notifier in main.vi and I want call my values in sub.vit
In attachment you can see my operation basicly.
Why my values cant coming in my sub.vit files?
Thank you.
(3,236 Views)
Why are you using a VIT, rather than a VI?
What happens when you run this code? What about with execution highlighting (the lightbulb icon in the toolbar)?
(3,216 Views)
Hi nathand. Thanks for your reply.
I reading high speed data from my device and i need monitoring datas from different channels.
I using vit because i need clone my graph and other indicators.
In attachment file its not my original project file. Its just simple example about how i used notifier in my project. I need forward my datas for  show in graphs or numeric indicators vs.
(3,210 Views)
If you don't supply code that demonstrates your problem, then it will be very hard to help you solve it. If the example code you posted works correctly, then it's not very useful in helping fix your problem. Please attach enough of your real code to show what you're actually doing, along with a more detailed explanation of what doesn't work. Does the Wait on Notification wait forever, or does it receive data but not the right data? How are you creating different notifier names for each channel?
(3,206 Views)
Hello nathand. Thank you for your reply.
I creating notifier in main vi. and ı can using this for storin in main.vi different loop.
But i cant call this notifier in  my .vit file.
Now you can check my vit file from attachment (but its have many sub.vi)
(3,184 Views)
Accepted by YFA
I fixed my problem with global referance.
And i found my mistake about notifier.
(3,161 Views)
