Call to WinAPI Kernel32.dll doesn't work in runtime
I have a dll call to the Kernel32.dll function GetVolumeInformationA. It works in the development environment and when I build it into an executable and run the executable on the development machine it also works, bu when I run the executable on the target machine with only the LabVIEW Runtime installed it does not run. It produces error code 21. Any ideas as to the cause of the problem?
Allen
(6,074 Views)
"CAW" wrote in message
news:5065000000080000007DC20000-1077587809000@exchange.ni.com...
Check if the dll versions are same on both machines. The Microsoft dll
history link is
http://support.microsoft.com/default.aspx?scid=http%3a%2f%2fsupport.microsoft.com%2fservicedesks%2ffileversion%2fdllinfo.asp&fp=1
HTH
Mohan Pawar
> Allen
(6,074 Views)
Your target and development machines are running different versions of windows?
In the call library function node of your VI diagram, make sure you have put "kernel32.dll" in the "Library Name or Path" entry and not a direct path to kernel32.dll like "C:\Windows\System\kernel32.dll". The kernel32.dll resides in C:\Windows\System for Win98 and C:\Windows\System32 for WinXP/2000.
I have attached VI's which perform the GetVolumeInformationA function. I tested the built application across both WinXP and Win98. The VI's are in LabVIEW 7, let me know if you need them in version 6.
(6,074 Views)
Hi Allen,
If I understand your problem correctly, I would lean towards making sure that you have all of your DLLs on the target machine and that they are located in an accessible directory. Good Luck!
Jeremy L.
Jeremy L.
(6,073 Views)
Whether the volume serial number will be unique ? My requirement is to have a unique identification, of the PC in which I am running my program
(5,421 Views)
