Calling LabView ActiveX Server from TCL?
Does anyone have experience calling a LabView ActiveX server vi from
TCL? I created a simple VI with one control (labeled "A") and one
indicator (labeled "B") and a +1 adder between them. I can load and
open the VI from TCL:
package require tcom
set lv [::tcom::ref createobject "LabView.Application"]
set viPath "D:\\National Instruments\\LabView\\Activity\\a.vi"
set vi [$lv GetVIReference $viPath]
$vi FPWinOpen True
But when I try to send in data:
$vi -namedarg Call A 1
I get the error message "unknown parameter A".
I have also attempted to duplicate the "ActiveX Server" example
from the LabView help file, calling "Frequency Response.vi". This
approach encounters the same error message:
% package require t
com
3.0
% set lv [::tcom::ref createobject "LabView.Application"]
::tcom::handle0x013202F4
% set viPath "D:\\National
Instruments\\LabView\\examples\\apps\\freqresp.llb\\frequency
Response.vi"
D:\National Instruments\LabView\examples\apps\freqresp.llb\frequency
Response.vi
% set vi [$lv GetVIReference $viPath]
::tcom::handle0x01335AE8
% $vi FPWinOpen True
% $vi -namedarg Call Amplitude 10
unknown parameter Amplitude
If anyone can point me in the right direction, or give me an
example of how to do this I would greatly appreciate it.
TIA.
Leslie
Message 1 of 10
(5,674 Views)
I have not used LabVIEW ActiveX VI Server with Perl but can give some
pointers about calling the ActiveX VI Server.
First when invoking the Call method, the VI must be opened and reserved for
call, that is setting the resvForCall parameter to True. It also expects an
array of strings as the parameter name list (these controls/indicators must
be on the connector pane) and an array of variant as the parameters values.
In a Visual Basic Script, that would be:
Dim lvapp,viref,paramNames,paramVals
VIname = "a.vi"
VIPassword = ""
resvForCall = True
paramNames = Array("file")
paramVals = Array("c:\data.txt")
set lvapp = WScript.CreateObject("labview.Application")
set viref = lvapp.GetVIReference(VIname,VIPassword,resvForCall)
viref.Call paramNames
,paramVals
This piece of code sets the "a.vi" control named "file" to "c:\data.txt" and
calls the VI.
It might be simpler to invoque the "Run" method. The VI is not reserved for
call on open. Before running the VI, use the "Set Control Value" method to
set the input controls (not necessarly on the connector pane). Then run the
VI and use the "Get Control Value" method to retrieve the
controls/indicators values when finished.
I hope that helps
Jean-Pierre Drolet
LabVIEW, C'est LabVIEW
Message 2 of 10
(5,673 Views)
In article ,
>$vi FPWinOpen True
I don't use LabView, but from the Visual Basic example I saw, it seems
the Call method takes two arguments. The first is an array of parameter
names and the second is an array of parameter values. Try to send in
data with the Tcl command
$vi Call [list A] [list 1]
Message 3 of 10
(5,673 Views)
"Chin Huang" wrote in message news:9q2n97$26ah$1@news.tht.net...
I'm unable to help the original question (don't know LAbView or VB stuff) but
just want to point out that [list A] is equal to A and [list 1] is the same as 1.
Bruce
Message 4 of 10
(5,673 Views)
"Bruce Hartweg" wrote in message news:...
> Bruce
I know what is supposed to be passed to the 'Call' method. Doing
this:
set inst
[::tcom::info interface $vi]
$inst methods
produces (among other things):
{1015 VOID Call {{{in out} {VARIANT *} paramNames} {{in out} {VARIANT
*} paramVals}}}
So the 'Call' method is expecting two parameters, both pointers
to variants. TCOM appears to be passing the correct parameter type
because the TCOM documentation says that a TCL List maps to a
one-dimensional array of VT_VARIANT. However, the results are
INvariant (bad pun intended):
% $vi -namedarg Call [list Amplitude] [list 10]
% $vi -namedarg Call [list Amplitude] [list [::tcom::na]]
% set i 5
5
% $vi -namedarg Call [list Amplitude] {incr i}
% $vi -namedarg Call [list Amplitude] [list [incr i]]
% $vi -namedarg Call Amplitude [incr i]
Who can help me with this? Who is the LabView Guru?
Leslie
Message 5 of 10
(5,673 Views)
Few more remarks that might help:
- The Call method expects variable arguments to return values: you can't
invoque it with arguments that are expressions or constants.
- For your "a.vi" in the original post, you need to connect A and B on the
connector pane.
- In your script, set a variable (say paramNames) to an array(list?) of
strings "A","B". You need to specify B also if you want to retrieve the
value of B after the call. Set also a variable (say paramVals) which is an
array of values for A and B. On return from the call, paramVals should
contain the value of A and B after execution.
Jean-Pierre Drolet
Message 6 of 10
(5,673 Views)
In article ,
>% set i 5
>5
The -namedarg option doesn't work the way you seem to think it works.
The -namedarg option provides
a way to specify arguments named from the
method's parameter specification. For example, you discovered that the
Call method takes two parameters named "paramNames" and "paramVals".
Tcom returns the error "unknown parameter Amplitude" because "Amplitude"
doesn't match either parameter name.
Both parameters of the Call method have the [in, out] mode, which means
tcom expects you to set the values you want to pass into Tcl variables
and specify those Tcl variable names as arguments to the Call method.
set names [list Amplitude]
set values [list 1]
$vi Call names values
Message 7 of 10
(5,673 Views)
cthuang@vex.net (Chin Huang) wrote in message news:<9q64bc$311t$1@news.tht.net>...
> In article ,
> set values [list 1]
Chin Huang is the ActiveX GURU! To complete the LabView helpfile
example:
# Interfacing to LabView via TCOM
# Start the TAU GUI as an ActiveX server
set viPath "D:\\National Instruments\\LabView\\activity\\a.vi"
$vi FPWinOpen True
# Create the parameter array
set names [list Amplitude "Number of Steps" "Low Frequency" "High
Frequency" "Response Graph"]
# Create the values array
set values [list 5 105 15 1005 0]
# Call the VI and get the results
# The Response Graph is returned in 'values'
puts $values
5 105 400 2000 {{400.0 406.238291234 412.573873162...} {...}}
Thank you Chin Huang!
Message 8 of 10
(5,673 Views)
lesliebrooks@my-deja.com (Leslie Brooks) wrote in message news:...
In my example I gave the wrong path. These lines:
should change to:
# Start "Frequency Response.vi" as an ActiveX server
Instruments\\LabView\\examples\apps\freqresp.llb\Frequency
Response.vi"
If you want to
invoke a VI that has been compiled, do this:
# Start the compiled "Frequency Response.vi" as an ActiveX server
set lv [::tcom::ref createobject "Frequency Response.Application"]
set viPath "Frequency Response.vi"
(Of course the EXE file must be registered with Windows as an
ActiveX server.) You can register a LabView-compiled server EXE like
this:
C>My_EXE_Name /RegServer
Message 9 of 10
(5,673 Views)
In article ,
>news:...
>same as 1.
>> Bruce
>this:
>set inst [::tcom::info interface $vi]
>$inst methods
>*} paramVals}}}
>% set i 5
>5
Try invoking the Call method without the -namedarg option. The
-namedarg option doesn't work the way you seem to think it works. The
-namedarg option provides a way to specify arguments named from the
Call method take two parameters named "paramNames" and "paramVals".
Message 10 of 10
(5,672 Views)
